Small Utility Trailer
P0234
BX
Nov 13, 2023
57
38
NoVA
I would avoid anything that folds up like the one OP posted if you are hauling anything more than leaves and mulch. If you filled that cart up with dirt a few times I bet you'd break it. 800lb capacity is really light weight. I have an Ohio Steel "15" cu ft. cart and even that with a 1k limit is small.
6,320
Every Spring, Princess Auto sells the 'mini farm wagon' for about $250. Had 3 at one time.GREAT wagons but lousy tires,bit better IF you put tubes in and keep35 PSI though )
I had a steel dump trailer until neighbour's tree cam a visiting... somehow it missed the cedar shed, attached cedar pergola and destroyed the trailer ,parked under the pergola. I was going to play 'pickup sticks' but he come over while I was at the Vets. I'll build a new trailer with 'scrap steel' from his dumpster come Spring ( 50 days ,not that I'm counting...)
Snowman7
May 20, 2020
406
312
Boyne Falls, MI.
I really like my MUTS trailer made in Canada. Tilts, holds a ton, same width as my 4 wheeler.
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
530
WI
Those look awesome, and will be a plan for the future, right now I need something small and inexpensive. Have some "tight space" landscaping to do this spring, after a hefty unexpected foundation repair...
They're about 300.00 so not terrible. I wouldn't consider a new metal yard cart. They bend looking at them. I bought what was a mid size running gear by farm tuff. It was rated for 1500 pounds also. I built it and being 180 I was flexing it.
I ended up buying a real 10 running gear for the same price.
That'd be too big for your needs it's too big for my lx and not save to tow fully loaded but just showing you want 500.00 could get. With spring coming up I'd keep an eye on consignment auctions. A lot of farmers might have something home made That'd be up your alley and name your price.
6,320
there's an untouched 'pergola' overhead as well. tree limb came from tree 25-30' to the right on neighbours property.HOW it missed shed and pergola is beyond me...
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
I wouldn't be opposed to the Harbor Freight 40"x48" trailer for general off-road use. Throw your own deck and sides on there and away you go.
Scroll through the pictures in the reviews for ideas.
jampy00
BX1880
Jan 11, 2024
98
41
Ontario, Canada
No sure about that, it is not "plastic" and I am sure with an 800 pound capacity someone has tossed some dirt/rocks in it... If they broke quickly the interwebs would be full of 1000's complaints
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
475
551
NE Ohio
I've hauled everything from broken concrete, concrete blocks, topsoil, compost, mulch, and lawn debris in mine, over the 5~6 years I've had it, with no problems or any signs of deterioration. The only 'problem' I've experienced with it has been soil/mulch/compost getting into the hinge pockets. A bit of scraping with a stick or hitting it with the garden hose quickly cures that.
jampy00
BX1880
Jan 11, 2024
98
41
Ontario, Canada
Thanks for that insight, I assumed as much.
6,320
Tossing jagged ,heavy rocks into any 'plastic' tub ,in the middle of a cold winter WILL probably shatter the tub...
BTW 'wagons' are nice as you can easily unhook,go do other stuff also more stable when hauling.
jampy00
BX1880
Jan 11, 2024
98
41
Ontario, Canada
True, but very unlikely I'll be doing that sort of work in the winter months.
6,320
I said that once, yet every winter city snowplow decide to 'rearrange' the rocks(50-150# each..) I put along the base of the hill 3 feet from the road.......... Tempted to put 1,000 boulder as a 'warning sign'.......
jampy00
BX1880
Jan 11, 2024
98
41
Ontario, Canada
Yeah, I'll need to strengthen up my mailbox this year I think, starting to get a nice lean to it from the plow.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
unlikely the OP's BX1880 would pull it if full !
"Full", no problem. "Loaded" might be. However, he did indicate light duty landscaping. I think the 1880 capacity is 1700ish lbs for towing. Even if he never puts that much weight in it, the added volume cap could be helpful.
P0234
BX
Nov 13, 2023
57
38
NoVA
So are you just looking for affirmation? Ok, its great, just buy it!!!
On the other hand, you may want to read the reviews, a few people mention cracks and flimsy build on homedepot.com
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
There is a small road legal utility trailer here but every once in a blue moon it'd be nice to have something even smaller. Years ago I gave a mini trailer to a guy at work because it was too small for anything serious and it seemed every time I went to use it one of the tires was flat. My first thought is I'd be better off with either something that could go QA on the front or 3PH on the rear..
7,347
I'm with chim and couple others - - my 3-point Carry All is my little trailer.
I have a Quick Hitch and can pick it without getting off the tractor.
With a BX I'm limited in payload, but 19 times out of 20 it's quicker, easier, and never has a flat tire.....
