Kubota L3301 error code PO563
Texas2323
Kubota L3301
Jan 27, 2024
George West, TX
I have a 2014 Kubota L3301 that has an error code of PO563. The voltage across the battery terminals is normal when the tractor is idoling. I don’t see any loose wires. Is the alternator the problem? How do I check to make sure it is the problem and how do I clear the code?
5,453
from the web... 'system high voltage'...
Potential causes for this code to set are: High resistance in the cable between the alternator and battery - possible Low resistance/open circuit between the alternator and the control module - possible Alternator faulty – most common
curious... what's the voltage at high RPM, just after starting ?
There is a 'technical' issue. Most DMM measure about 3 times a second,gives us humans a chance to read the meter... The tractor's computer may read faster, and see a 'high voltage', maybe once, trigger the error code. It'd be nice to 'clear the code' ,see if it happens again.
3,010
1,471
P0563= Battery Voltage Abnormality
You can clear the code using the attached pdf.
Clear the code, and run the tractor to see if an error code comes back.
Texas2323
Kubota L3301
Jan 27, 2024
George West, TX
I was able to clear the error code and it seems to worked. Started the tractor back up and it is not registering an error code at this time. Thank you, much appreciated!
