Saw this on Marketplace
5,160
2020 B2650 with turf tires loader arm with bucket, new cutting edge Problem was it got hit by a tree someone who is mechanically inclined should be able to fix us up relatively cheap. I got a price for a hood 800 radiator was 600. I’m sure you would have to spend close to. 1800 for everything total.  The machine does have third function hydraulics for the front. I will leave with the machine. Only reason I’m selling is because I bought a new one.
I told the seller that it was more like $3500, not $8500. What are your thoughts? Only 1 Picture!
JimmyJazz
1,273
805
Pittsburgh, Pa
Even if you replace the bolt on or readily/easily replaced pieces there will probably be pieces that will remain out of square so to speak. Like the frame ,maybe loader arms. I don't know how important that might be on a tractor. Probably not very. I think $5,000 for the tractor and upwards of $5,000 for parts with you supplying the labor would be a good deal if you enjoy fixing things and have the time. Go for it.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Looks like a lot of work and also a lot of unknowns. The bonnet looks pretty beat in to think it only got the rad. I don’t own a b2650 so I’m not really sure what’s going on directly under the damaged areas. Loader is definitely f ed up. Looks like more than 5 grand in parts to me.
What did the seller respond with to your 3500? It would have to be something super low or cheap. And even then who knows.
Jsjac
B2650
Feb 13, 2022
241
388
Looks like the right side loader arm is bent.
Does it come with the trailer it's on?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,095
1,090
E.
in the add it says........... "Only reason I’m selling is because I bought a new one".
Me thinks maybe there might be another reason or two its up for sale.
7,540
That tractor is tweaked so bad it only good for some mechanical parts. Seller thinks after purchasing two parts you'll have a working machine... not hardly. He's as full of it as a Thanksgiving turkey!
PaulL
B2601, MX5200.
Jul 17, 2017
2,775
1,774
NZ
I wouldn't buy it.
But, as an optimist, I'll say that photo doesn't tell you everything you need to know. The trailer isn't level, the hood is bashed in, it's hard to tell if the loader is bent or not. If it's genuinely the hood, the ROPS, the radiator and you can establish nothing under the hood is busted.....it could be fixable and be a great machine. You'd want to know what you were looking at and look very closely before you took it on as a project though.
Nicksacco
Sep 15, 2021
764
502
Bahama, NC
Wow! I can't see much from that pic to decide on much.
I would have a look however for fun.
6,252
so... instead of spending $1800 for some parts, the guy forks out $30K for a new one ???
only posts ONE picture....HUGE red flag !
curious, can you even BUY the ROPS, in the USA ? AT KUB CDA parts, no prices are shown.
hmm, anyone else think the seat is a little 'wonky' ? Bet there's a LOT of damaged 'bits and pieces' under the hood. Hopefully engine wasn't running at the time the tree came to 'visit'.
To me $3500 is generous
BAP
Dec 31, 2012
3,130
1,261
Looks like left rear tire is either low or flat, but could be the trailer. Obviously, it was sitting right where it is now when the tree fell, seeing how the box trailer behind is crushed and there is pine limbs on the bucket area. I think it is impossible to determine how much actual damage there is and value without looking at it in person. Very likely there is rear end housing damage on the tractor.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,412
614
Richmond, Virginia
If the tree that fell was heavy enouhg to crush the ROPS, all that energy went in to the rest of the machine.
Run fast, run far from it.
My best offer would be $500 if they include delivery.
old and tired
1,919
1,297
I'm thinking the pine tree fell on the tractor and trailer where it's sitting. The landscape rake is in at least 2 parts... Not sure about the snowmobile trailer behind but pine branches are on top of it, too...
4,065
I suspect that was an attempt at Humor…. ?
ken erickson
Nov 21, 2010
1,393
2,564
Waupaca Wisconsin
If only he had not drilled the two 1/8 inch holes in the ROPS to mount the light bar, It would not have failed and would have protected the rest of the tractor! :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:;)
Reactions: 8 users
5,184
I am certain that Kubota corporate would agree! :ROFLMAO:
7,540
There must be a lot of folks selling things that have a good sense of humor, if that is what it is. They say things like it's an easy fix. I always think if it was so easy why didn't you fix it? Or, it won't last long. Or, my loss your gain.
