Hello welders and fabricators. I want to weld up a carry all/ballast box that will attach to my adjustable cat 2 3 pt receiver hitch on a L6060. I've drawn a crude pic of what the base of the frame might look like. I'd use 2x2 square tube to fit into the lateral receivers as well as the option of tying into one of the center receivers. The cat 2 can lift approx 3000 lbs. What wall thickness of the tubing would be sufficient to safely carry that load? And would using the 2 lateral receivers be sufficient or should I tie into one of the central ones as well? Any gussets needed? Thanks in advance.
Best...
Best...
