I have a BX 2370 after about 20min of run time it stops. if you let it sit for 20min then it will start. If you keep the tank full then no issues, fuel pump ?
Yes I tried that and did clean the tank to no luck.yup, Lug66 said it best !
one test though... unscrew fuel cap and run...a really,really long shot is the cap's not venting, forms a partial vacuum, stops fuel flow. Unlikely but easy to test.
Yes I do hear the pump running, just thought maybe it doesn't have enough pressure.With the key in the on position - do you hear the ticking noise of the fuel pump?
IF so - then you have the problem the others have said.
IF there is NO ticking of the fuel pump, the tractor is running on gravity flow, once the tank is lower in diesel the flow is reduced.
The pressure on that pump ..... is very small, like 3 psi.Yes I do hear the pump running, just thought maybe it doesn't have enough pressure.
