Wheel wobble
dieseldenfl
M4700DT
Jan 12, 2024
Florida
When turning wheels left or right when moving either forward or reverse, both wheels wobble and gear lube is leaking from both inner wheels. No split lug nut wells, or loose tie rod ends.
Nicksacco
Sep 15, 2021
760
497
Bahama, NC
I am assuming you're talking about the front wheels only.
But some pictures would be helpful.
My first thought are worn/damaged wheel bearings - but I hate to jump there without more information.
How long has this been going on? Old tractor? What other info can you provide?
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Sounds like some loose bearings but really need more info on the tractor to say anything more. Is it the m4700?
bbxlr8
Mar 29, 2021
448
309
Eastern PA
FWIW - Was the wheel bearings combined with a weak hub design on my smaller old Ford. Know it's apples and oranges vs your M4700...
dieseldenfl
M4700DT
Jan 12, 2024
Florida
Thanks for a quick reply!
Tractor is a 1999 M4700, 4WD with almost 1300 hrs.
The l/front started about 4 months ago, and r/front started a few weeks ago. After each one started the wobble, it began leaking gear lube from bearing hub(s).
dieseldenfl
M4700DT
Jan 12, 2024
Florida
Thank you for a quick reply!
It is a 1999 M4700 4WD with almost 1300 hrs. The l/front started the wobble roughly 4-5 months ago, with the r/front following suit 2-3 weeks ago. After each started wobbling, they began leaking gear lube at/near bottom of gear hub.
