Kubota M4500 and M4500DT
Fishfarmer
Kubota tractor M4500DT Kubota excavator KX161-3
Aug 8, 2021
Before I bought my tractor an M4500DT someone must have run it in to a tree or something, they replaced the radiator and hammered out the front bonnet panel, but there is no front panel radiator grill with the lights etc.
There is a wrecker with fair quality parts off a M4500 which says "low profile" on the side. Does anyone know if these panels will fit a M4500DT. He also has a front off an M4500DT but that one is pretty rough.
8,764
Thanks Wolfman is the M4050 the same also?
Yes and NO
While the M4050 grill does match the US M4500 and the M4500DT
It does not match the part numbers for the M4500 and the M4500DT AU version.
You being in OZ would make me think your M4500DT is the AU version.
It might just be an esthetic thing but no way to know for sure.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
If searching salvage don't limit yourself to just Kubota. Hesston, Oliver, White and Fiat all used those same body panels for various models.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
670
278
Herald Calif.
Check on the Bare-Co web site. They have the nose for a Fiat. I believe it's the same.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
445
92
NZ
From tractordata photos looks like Fiat 450, 460, 480, and may be 500 have same nose shape as M4500, the Fiats had headlights mounted on each side of the nose, not on front. In any event the head lights can be added somewhere suitable.
