I recently bought an MX5100 and performed an engine oil change. I goofed and put a full synthetic 10w30 that isn't rated for diesel engines (it's a gasoline SP rated oil). I've only ran the tractor for a few minutes since changing the oil (basically to circulate/top off). Is there much concern running the engine a few minutes to drain this oil out or would you drain it cold? Would you use any sort of flush solution? Or maybe first replace with cheaper diesel oil, run for a few minutes, drain and then add a quality diesel oil? Any concerns with reusing the basically new oil filter even though the filter media has been saturated with the SP oil? Thanks for any advice.
