Kubota bx2350 drops RPM
carlwagner
Kubota Bx2350
Jan 9, 2024
Chamisal NM
Once I begin asking it to work, like using the blade for snow or pushing with the bucket the RPMs will drop and stall or almost stall. May work fine for 10 or 15 minutes before it quits. Fuel filter has been changed and air filter cleaned. Help.
5,426
What range (transmission) are you trying to do heavy work in? Are you mashing the pedal?
Remember, the HST pedal is not like a gas pedal. The more you mash it, the less power you will have.
may want to try running it with the fuel cap loosened a bit to make sure that the the tank is venting.
carlwagner
Kubota Bx2350
Jan 9, 2024
Chamisal NM
How old is the tractor ?
How old is the fuel?
When was the fuel tank properly cleaned ?
The tractor is about 10 years old. I put winterized diesel fuel in it in November. I don't think the fuel tank was ever cleaned. I use the tractor only about 6-12 times a year on average.
carlwagner
Kubota Bx2350
Jan 9, 2024
Chamisal NM
I'm used the tractor in Low range. Thanks for telling me about the pedal. I'll try your suggestion although I've never had that problem since I've had the tractor.
dlsmith
BX2230, LA211
Nov 15, 2018
1,274
859
Goshen, IN
Does a BX2350 have one or two fuel filters?
My BX2230 has one between the tank and the electric fuel pump, and another just before the injection pump.
armylifer
Mar 26, 2013
2,151
924
Thurston County, WA
When you say that the fuel filter has been changed, does that mean both of them? There are two fuel filters on your tractor. You need to change both of them to be sure you get the full fuel flow to the engine.
