Everybody loves an update.
I have got 5 of 7 cyclinders back from the shop, cleaned, inspected and resealed where neccessary.
I also have the valve block from the shop.
In the mean time I managed to get some time to improve the hydraulic oil tank in 3 minor ways
1. A boss for a magnetic sump stud. Although I can't see how metal will get into the tank if the filter is working properly on the return.
2. a sight level and thermometer.
3. a valve on the Pump suction line so that I can isloate the pump without losing a tank worth of oil.
Measure and mark
Nuts in place
Everything welded up.
Typically, the job was small, but there was some yak shaving to get there, building a welding trolley, buying a new weldng mask, a saga with gas bottles and regulators, a workshop rewire and a misadventure into chinese mini excavator attachments, which are so cheap but also too small for my KMS180.
With the weather heading for a short period of positive temperatures, theres is a chance to clean all the lines and get the cylinders I have fitted while waiting on the leg cylinders.
