Tire Chain Tensioners
Tioga Tim
B2620
Nov 11, 2020
46
17
Upstate New York
Got a set of small tire chains for the front of my B2620. I don't see how I will ever keep them on without some kind of tensioner. I have never needed to use them on my big tractors, so I don't know anything about them. I see ones that will fit on the outside of the rim obviously. But there are also some that can be put on the inside, around the axle. What should I try? Does it make sense to do both?
SDT
Apr 15, 2018
3,681
1,406
Tensioners, bungees, etc., are not needed if tire chains are properly fitted and installed.
Tire chains are manufactured to fit multiple tire sizes and nearly always need to be modified for proper fit, though few do so.
I've bought, fitted and installed multiple sets and never had any need for tensioners, etc., even after decades of use.
3,057
AS chains get used - as with all metal chains they do stretch, and with that - they need to be secured better to the tire.
Go to wallyworld or another "cheap" place and get the 4 pack of 1" ratchet straps.
Cut off the excess ( yes I know it will be a waste) and then hook them across the diameter. AS you use the chains throughout the year - you can easily ratchet another click, thus keeping them snug and tight.
4,122
2,815
I'd go with chain, s-hooks and HD tension springs over a bungee. I haven't had much luck with bungees these days and find they are only good until you use them the first time.
6,285
The chains designed for 'turf tires' won't properly fit any other tire tread, and may not fit another brand of 'similar' turf treaded tire.
I let some air out,chained up, inflated to 15PSi, added 1 bungee per side..15 YEARS ago. Snowrider works great,even with a bit of slop in the chains. No snow here(2" fluff doesn't count ) ,so haven't had any fun this winter.
MuttCat
86
Dorloo, NY, USA
Here's what I do with chains; air down the tires a couple of pounds, mount your chains, air up the tires to snug the chains. Easy, no tensioners needed.
3,057
Excellent idea - but over time, those little guys will stretch to where air can't help!
7,323
I use short rubber tarp straps. Not much room inboard on a BX, and I don’t have spacers.
Keeps them tight.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
I used chains on a 2WD tractor years ago. I used "screen door" springs and S hooks. Two springs per side. No pics, but the springs were attached in a V pattern. Hooked at 12:00, looped around at 8:00 and other hook at 4:00. A second spring went 10:00, 2:00 and 6:00. That pulled pretty evenly at six points.
MuttCat
86
Dorloo, NY, USA
I'm not sure what is meant by stretch. If you are speaking of the chains stretching, well steel doesn't stretch, it wears out, like a bike chain, indicating a need for replacement. Rubber too gets old, cracks, breaks...falls off.
YMMV. If your tires are filled, remember the air valve must be up top when airing up or down.
I went with the R14 tires (?), the ATV tread jobs. Haven't used chains in couple of years now.
3,057
So --- a steel timing chain does not stretch? A steel chain on a chain saw does not stretch?
Ok - lets use another word then - elongation
AS those links in a chain on a tire roll, the pull on each link is tremendous - they elongate! and with them smashing against the road surface also flatten out.
A chain will deform and stretch throughout it's life as the load is placed on it and then removed to be placed again.
5,255
1,057
After years of coping with a 2WD Nuffield 465 I learned the critical aspect of tensioning tire chains is not to go from one side of the wheel to the other but rather get a metal circle from places like TSC. I think they are used with horse harness stuff. By pulling each part of the chain towards the centre of the wheel the chains seemed to stay much more uniform.
Rubber banjo straps are not much good compared to metal springs. Their tension changes with moisture absorption and temperature. the springs remain constant.
You only need to tension one side of the tire chain!!
On my Kubota M7040, I bought expensive TRYGG chains which are made to fit the tire with no fiddling.
When younger I could not afford this quality of tire chain.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
I use the ball type bungee cord loops (like they use for canopies and etc) and just go as far as they will reach between links on the outside chain loop. Two maybe three each side of the tractor depending on how I feel. Flip the ball through a couple times so they don't pop out. They are cheap, will usually last a couple seasons unless I loose them or use them for something else over the summer.
On the tractor for low speed operation (as opposed to truck or car chains) your chains don't have to be TIGHT, just snugged up so they aren't slapping around and catching on something. Unless they are way over sized it doesn't take much to do that. Chains sized for larger rims 24-28 etc might be a different matter because of the heavier gauge chain.
I used to do the air down and air up thing. Giant pita. Added a couple links so I can do the bungee rout and have had way less aggravation.
Even with bar tires, weights and a little extra ballast on the 3 point of my little snow blower tractor there's no replacement for the chains. The with vs without traction isn't even close.
Stmar
B2650HSDC
May 23, 2017
949
58
Buffalo, Wyoming
I use a similar system. The center is from a broken bit horse bridle and the spring tensioners are trampoline springs, bought those online, 15 pack a lot cheaper than single springs from hardware stores.
