Seems about 100 to 150 lbs heavy and $1k light. Check the specs for AR steal vs A36. Check the number of hinges (two or four) and the tine thickness. Check the hydraulic cylinder shaft diameter and hose routing. And check the pivot pins, greasable or not? Just a bolt vs a real pin?
Couldn’t find the unit you mentioned (60” standard duty at 610 lbs). I did find the 66” HD Class and 60” C Class. Both are using mild steel, A36, vs AR (abrasion resistance) steel. Also noted Schedule 40 tubing, that’s not impressive (but it is cheap). That’s one reason they are less expensive. The pivot pins and hydraulic rams looks decent enough, the tines are 1/2” plate and they need to be since they are mild steel (A36), about half the yield strength (36 ksi) of even the lower grade AR steel (70 ksi, IIRC).
I bought my grapple from CID early 2023, about $3k on the west coast, made on the east coast. 66”, single lid (four hinge). AR steel.
