Long bushing for Cat 2 lift arms to mount Cat 1 implements?
trackman23
MX4800
Nov 22, 2023
121
22
NC
I seem to have quite a bit of space on either side of my lift arm when i mount all of my implements and as a result, the standard 1.75" long bushings dont have much area to bear on. Any idea where I can get some longer ones? Online searches at tractor supply and agri supply don't seem to show any options.
Thanks,
SDT
Apr 15, 2018
3,690
1,414
I use multiples.
Sometimes cut to fit.
6,308
hmm
support bushings only have to be as wide as the lift arm 'ball' contact width
push lift arm in , to where pin meets implement,
then fill outside 'gap' with washers( spacers) to where lunch pin fits
Heehaw
MX5400hst Kubota Z726X
Oct 4, 2022
108
117
I had the same issue with my BushHog and did as SDT said about using multiple and cutting one down. It took a little over 2.5 bushings on each side.
trackman23
MX4800
Nov 22, 2023
121
22
NC
This is a typical situation…not much bearing surface on that bushing. I like the multiple bushing idea.
Foreverworkin
MX6000, B2601
Aug 27, 2026
Churchville, MD
Thanks,
LandPride part number 326-236D. 1-1/8" OD x 7/8" ID x 3-3/8" Long 20260827_084403.jpg 20260827_084940.jpg
