airbiscuit
So, what are you going to do? One way or another, you have to get that forward cutting edge to extend as far below the side panels as the rear one. You will not be able to shorten the top link enough to that Tyrannosaurus cutting edge to engage.
I think you have two options.
Remove the canted angle iron mounting and replace it with one at the proper angle
or
Drill new mounting holes in the existing angle iron low enough to properly position the front cutting edge.
It is possible that the angle iron mount was welded in at a cant from the factory.
or
