It actually has nothing to do with the gasket it's three O-rings that seal the oil passages.So looking at a couple diagrams it appears the oil pump bolts to block behind timing cover, while oil filter mounts on timing cover itself. This means pressurized oil crosses from block to timing cover in at least two places. Given what youve said, the simplest answer is that the timing cover gasket is misaligned or torn and you have pressurized oil leaking from the timing cover gasket abd simply dumping back into the pan internally.
IF there is an oil pressure relief valve in the timing cover (dont know) and you had to pry on the cover anywhere near it, that could be an issue. I once had that happen.
THANKS!!!! for the replys. It has been down a while. I got frustrated and decided to crank it. I had turned it enough that I thought it should have been bumping the oil pressure guage needle by now. I came in the house and got even more mad. I decided it would pressure up or sieze. Tightened the injector lines. By the time I had cleared the last air from injectors I had oil pressure. Must or had a air pocket.Removed front cover and replaced fuel injection cam. Replaced gasket and replaced cover. NO OIL PRESSURE NOW. I think it should have done picked up. I forced primed thru sensor port, but still not putting out any oil. What's the next step?
Pretty sure I had it right, but when I had covid I ran a fever for 12 days. Yes 12. My short term memory is void. I have to continually secound guess myself. I thank yall for the replys.Take it back apart and figure out what you left out, or what didn't get put in properly.
You not need to prime these engines.
