Need a debris fork for pine needles
willyC93
L2500DT,LB400fel,7.5'snowplow,6' landscape rake,backblade,homemade pine needle r
Oct 25, 2010
29
Post Falls, Idaho
I made a rake to remove pine needles from my road before grading and preparing for snow plowing. I have used a manure fork for years but now need a front loader debris/manure fork to pick up and load them. Any ideas and photos would be greatly appreciated.
Vlach7
L47 305DT JD500C
Dec 16, 2021
453
330
Frazier Park Ca
Love my Debris Forks for brush and firewood, just couldn't spend $4000+ for Grapples and 3rd function, compared to $400 for Debris Forks from Titan. Never used Grapples, bet it would be fun like my BH.
Vlach7
L47 305DT JD500C
Dec 16, 2021
453
330
Frazier Park Ca
I use a 7' 3pt rake to get big jobs done, one of my favorite accessories, along with my debris forks.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,187
879
PNW-WA
A 3pt Straw Rake sounds like a must. They're basically a big Grass DeThatcher.
Hand raking as little as possible.
willyC93
Oct 25, 2010
29
Post Falls, Idaho
I built a pine needle rake which does a good job but I am loading the front loader and shelf by hand. I am thinking about building manure forks for the front loader with 1"X1" bar stock 16" to 20" long tines but am concerned about tine spacing.
My road is 1/2 mile from the far end to the burn pile and I want to make the trips with the tractor and not the trailer.
Lil Foot do you drop many needles with your tine spacing?
Thanks, Bill
3,580
Thanks, Bill
No, the needles really lock together.
I found we can scoop the piles with just the forks, but an assistant with a rake or manure fork can stuff/pack a lot more needles in/on the forks & bucket.
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
44
31
North Branch, Minnesota
I built this years ago after I built the loader for the Case 446. Needed something to clean waste hay out of the winter goat pen.
3/4" bar stock with the ends cut at a bevel, welded to a piece of strap to keep them spaced properly. Back end is 1/2" by 1" bar stock with angle brackets bolted to holes in the sides of the bucket. A couple pieces of angle bent over the front edge of the bucket to keep it in place.
Works awesome for cleaning up waste hay, downed branches in a pile. Would think it would work for pine needles.
Sorry about the dirt clods stuck to the ends of the spears.
Mike
willyC93
Oct 25, 2010
29
Post Falls, Idaho
Found jbolt001's DIY Straw Bucket and think that the use of concrete form stakes is the way for me to go. I'll use 1 1/2" square tubing for the frame and 3/4"X36" form stakes on 4" centers for tines and will attach it to the bucket. jbolt thanks for the idea. I feel guilty for the theft but will soon recover.
