I have no plans for a hoe. I am just changing the outlet mounting design. Going to replace my panel mount two way sleeve couplers with the push/pull connect under pressure Faster style used on the big tractors.Dan, I assume that your future alterations of your existing setup are to accommodate a backhoe?
Goal is to make the individual sets of outlets modular and stackable. Similar to the OEM outlet blocks used on most other Kubota series but using base mounted Faster 4SRHF couplers like on the M6. On some machines the ROPs is a convenient spot for them but on my L01 I think I will mount them right behind the seat like the picture below of an M6
