it started with a stuck valve, pulled the head got the both valves working, needed head gasket 2 wrong gaskets, got that together,, carb was all mucked up off apart together 3 times nope what ever is clogged is clogged real good,, order a new carb from jacks,, 2 days later it comes,, choke lever is broken off,, called they replaced the carb,, cool,, wrong carb gaskets,,,, called jacks and got the right ones yesterday,, by now I dont care if this POS ever runs,, So I was out getting the mail and thought, wth I ll try to put it together. These honda motors have 2 bolts and you dont have enough fingers to hold every thing cause the bolts go through the air box through the air deflector then the carb then the insulator in to the motor ,, OH and you have to hold all the gaskets in place while your doing it.
First time ook the carb off the better part of 3 hours getting it back on,,,, grrrrrrrrrrr...
So yeah Im kinda happy,, well it was running today,, I ll see that happens tomorrow
