Is this dry rot?
Whiskey Mike
B2601 BX5455HD, RCK60-32,
Feb 16, 2022
42
15
Brewer, Maine
I noticed one front tire has chunks missing from the corners of nearly every lug. Outside storage, limited sun exposure, 4 maybe 5 years old. Tires not abused. Used for snow removal only. Any idea what's going on?
5,175
3,099
When I bought my B7100, it had old (but usable) tires on the rear, with exactly that kind of damage on one side, maybe a little worse.
It turned out the stabilizers on the 3 pt hitch had been broken & welded so many times that one side could no longer be adjusted correctly, allowing the 3pt arms to occasionally swing far enough over to hit the corner of the tire.
Just a thought.
Hodge Stabilizers solved that problem.
4,966
Agree with @Lil Foot. Looks like it’s been hitting/rubbing on something. If inside of rears, lift arms would be the prime suspect. If fronts, hitting something at the extreme end of range of motion. Looks exactly like lift arm interference damage.
Dry rot/UV degradation is more of a general cracking and usually shows up on the sidewall first since that’s where the most flexing is going on in normal use. Chunking out of lug ends without severe cracking elsewhere isn’t consistent with dry rot.
6,932
Hard to tell from your photos' vantage point what side of the tire is damaged.
Looks confined to the lugs. .
If the damage is the inboard side of the tire, I'm betting a there's good chance it's cause by lower links of the 3 point hitch just like Lil Foot experienced.
Whiskey Mike
Feb 16, 2022
42
15
Brewer, Maine
Ok thanks guys... the damage is found on both front tires inboard side. Starboard tire is much worse than portside. There is nothing for the tire to run into at the extreme ranges of turn.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,431
1,719
Kalamazoo, MI
OP stated the damage is in the inboard side of the front tires so how could the 3PH stabilizers cause this type of damage??
I would be more inclined to suggest scrubbing caused by turning around on pavement due to the caster angle of the front tires. Running in 4WD would exacerbate the situation.
6,932
My bad - - I missed the front tire part....
4,966
Very
Very possible if there’s no potential scrubbing on something stout due to interference. But it ain’t dry rot.
5,425
steering stops (limiters) in place?
not sure if your model uses them
5,152
Wild animals noshing on your tires because they are hungry. Put out some food for them and they will leave your tires alone.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
Sure looks like the tires are chunking due to scrubbing. Too much friction from being in 4wd on a surfact that isn't slick enough.
Bmyers
May 27, 2019
3,456
4,310
Southern Illinois
When I think of dry rot, I think of stuff like this
To me, not a tire expert, but that looks like damage and not dry rot.
3,099
I guess I should have been clearer; I brought up my situation as an example of damage caused by rubbing rather than dry rot.
jyoutz
Jan 14, 2019
3,386
2,430
Edgewood, New Mexico
Could it possibly be a matter of defective tire rubber?
