Top link extender
Mark at WJ
Kubota L3902
Aug 29, 2022
12
North Carolina
I recently purchased Pat's quick connectors and they work great. The issue is that I have a hydraulic top link that is now about3 inches short. Does anyone know where I can buy an extender to attach to the tractor?
2,839
Mark,
with an extender - you will need to make it sure it is rigid enough so both up and down will have the pressure it needs.
You may need a new longer top link to make sure that it works as planned.
5,728
if your top link is 16", you'll need to buy a 20" unit. that'll give you the same range of motion...
I've seen a section of chain used as an extender( but NOT ridgid....), section of bar with holes 3" apart, is ridgid.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Sounds like solutions are moving further away. Buy a Quick Hitch?
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
45
27
NJ
I had the same Issue. Here's my go at it. The horizontal pieces are 3/8x 2" flat steel bar. The diagonal pieces are 3/8 x 1.5" steel bar. Nuts and bolts are 1/2 inch. 7/8 drill bit also needed for the hitch pin holes. Put this in roughly 18 months ago seems to be holding up so far. Did a bit of welding but that's not required.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I had the same Issue. Here's my go at it. The horizontal pieces are 3/8x 2" flat steel bar. The diagonal pieces are 3/8 x 1.5" steel bar. Nuts and bolts are 1/2 inch. 7/8 drill bit also needed for the hitch pin holes. Put this in roughly 18 months ago seems to be holding up so far. Did a bit of welding but that's not required. View attachment 116814 View attachment 116816 View attachment 116817 View attachment 116818
That looks to fill the need. The bar on the right, whats it's purpose?
6,710
Nice simple extension! Easy for some to visualize concepts and put into action. Nice job.
