PTO Driveline replacement
bpdaniels
B7800 Tractor, B2782 B2784 Blower, LA402 Loader, B2761 B2762 Mid PTO
Oct 11, 2020
Va
Hello,
I have a B2761 quick hitch/subframe I use for a front end snowblower attachment. I made a bone-headed mistake this year, when I swapped out the belly mower and attached the subframe, I forgot to attach the driveline to the mid pto shaft and drove off. Needless to say it ben the driveline pretty good, and in two directions (not easily straightened).
Although the part # I need on page 3 of the attached parts manual is 70060-01147, it would be easiest to replace the entire driveline, part # 70001-00623. Best I could find OEM is nearly $400 for the driveline, and $250 for the one component.
Wondering if anyone has found an aftermarket for this part(s)? Weasler?
Thank you.
10,973
Your very very unlikely to find aftermarket on these parts.
bpdaniels
Oct 11, 2020
Va
That's what I thought. Thank you.
bpdaniels
Oct 11, 2020
Va
Well, I took it to a fab shop that specializes in driveline repairs, and they said they could 'try' to straighten it, but because it is bent in two directions, could not 'guarantee' they could get it to an acceptable tolerance. Hence my looking for an alternative.
My concern is that if it isn't, it will eventually damage the PTO seal, bearings, etc., and I will have wished I paid full retail for the part.
Thank you for your reply.
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
When you had it at the driveline shop did you ask about replacing the tube? Cutting the ends off and replacing the tube is something they should be able to do. I had a shaft repaired like that a few years back. The cut it, replaced the tube and balanced it. It was not cheap, however it was less than the cost of a new shaft.
cthomas
LX2610 HSDC
Jan 1, 2017
864
576
La Farge Wi
I had to replace just the tubes on my late fathers JD tractor as those green bastards wanted $1800 for a new driveshaft for the front wheels. Did this while I was working at a driveshaft shop. Did have to buy 2 sections of metric splined tube. Still use one section as a cheater bar for my ratchet.
MOOTS
MX6000
Jun 27, 2019
2,231
2,847
Canton, Georgia
I just did that recently at work.
1362F09D-DA5A-4694-8C21-817FCE6B936A.jpeg EFE50206-E698-4CC5-A526-61DF8854BDE7.jpeg 219C4608-883D-4E98-BF76-4F789A3CC82A.jpeg
Turned out not terribly wobbly too.
5,163
Is it a solid shaft or a tube? If it is a tube most driveline shops will cut it off in the lathe and then weld the ends to the tube and balance it. Cost is a factor that I can't guess which way would be less expensive.
7,201
Hello,
Thank you.
Your bone head mistake can be fixed for a measly $275/$400? Pay the piper.
Dustball
2016 B2650HSDC
Sep 15, 2023
519
383
Hudson, WI
I was able to buy all of the parts (Weasler) to build a new fixed length mid-PTO shaft for my B2650 and bring them to a driveline shop to have them build it for me. The old parts had 900 hours on them and were worn out. In the end, it ended up being a little more than buying the whole shaft new from Kubota.
5,163
Did you figure out that this was going to cost more before you made your purchase or only after you acquired all the parts? The reason I ask, is if it is more expensive the way that you went, then why didn't you purchase a Kubota shaft and be done quicker with less running around? After the driveline ship does its work, how much more expensive is the whole project going to be versus a new Kubota shaft? Are the components you purchased a better quality than the OEM shaft?
4,116
2,812
Labour and shop rate isn't free in the western world. There's even a cost to my own free labour in tools and shop time.
Dustball
2016 B2650HSDC
Sep 15, 2023
519
383
Hudson, WI
I had about $180 into parts and shiping. What I didn't know was how much the driveline shop would charge which ended up being $250. I was thinking it'd be $150-$200 but the driveline shop had difficulty with securing the smaller than normal Kubota parts in his machinery. In the end, I paid about $20 more than what I would have paid purchasing from a Kubota dealer but at least mine is balanced.
The parts I have are the same as OEM since Kubota uses Weasler parts for the driveline. I hate paying Kubota/dealer prices for parts so I try finding the actual manufacturers or alternatives whenever possible so I'm not reliant on Kubota.
I'll get the new shaft back into my hands next week. I'll take pictures showing the old vs new parts side by side. The only difference is that the new slip yoke is a bit longer than the original which is perfectly fine to me. Longer = less sloppiness on the splined shaft.
Shared parts for the mid PTO fixed length shaft
Tube
1.5" dia tube
33.5" weld to weld (for my particular shaft)
Weasler 604-0600 for 3 ft or 602-0600 6 ft
Weld on Fixed Yoke
For 1.5" dia tube
Kubota 70060-01148
Weasler 702-0600
Spring yoke
Kubota 70060-02803
0.984 (25mm) x 10 splines
Weasler 105-0610
Slip yoke
1" x 15 splines
Kubota 70060-01148
Weasler 812-0615
U-Joint
Cap diameter .965"(31/32")
Outside width 2.300" (2-9/32)
Kubota 70060-01020
Weasler 6 series 200-0600
Weasler 6 series extended life 201-0600
Moog 861
ACDELCO 45U6001
Bearing (on subframe)
1"ID
5/8" bolts (.650" hole), 3.90" spacing (must check when ordering)
Kubota 70060-00387
Actual mfg and pn- FK Bearing UCFL205-16
NTN UCFL205-100D1
FAG UCFL205-16-J7
Shuster UCFL205-16
