Automatic transmissions in cars are valved or adjusted so that there is overlap between the gears to minimize the lag or abrupt change in torque when you shift. The two adjacent sets of clutches are actually both partially engaged at the same time, momentarily. This is to satisfy the needs of the 'typical' driver, in the quest for 'drivability'.
So-called "shift kits" for these transmissions come in a wide range of aggressiveness to more-or-less eliminate that overlap or lag. Gives nice CRISP shifts! If I get on my 6000-pound Cummins truck (with a moderately aggressive shift kit in it) it will chirp the tires when it shifts from 1st to 2nd, because there is much less overlap between the shifts than 'stock'.
I doubt anyone is marketing shift kits for the GST, just sharing a concept...
I don't know anything about GSTs, but for automotive ATs, it is also possible to adjust line pressures and band tightness to change drivability as well. That's not something for the amateur to play with. You can toast an AT very quickly if you over-tighten the bands! [Been there, done that.]
-Paul
