Wanting to add rear remotes to My new L3560HST ROPS
Mecomk
L3560HST
Nov 14, 2023
Santa Fe TX
Hello Everyone. I’m new to the group and this is my first post. I would like to install 3 rear remotes to my new L3560 HST Limited. Is there one kit I can buy with all the brackets hardware hoses valves levers O rings etc. If so can you provide a link?
Thanks for the help
PaulL
2,632
1,606
NZ
I'd recommend contacting Messicks directly and asking them.
This thread has some good knowledge - on working out what functions exactly you want (float, detent etc).
5,778
Thanks for the help View attachment 116223
Yes. Actuslly sold as muliple wholegoods kits by your friendly neighborhood Kubota dealer. The wholegoods kits for three factory remotes will run you better part of three grand.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,438
1,733
Kalamazoo, MI
Summit hydraulics makes a hydraulic multiplier where you can turn one remote into six or eight for way less $$. Good Works Tractors features them in his videos and gives a discount code as well.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Maybe consider adding a third function to the FEL too while you’re at it. Only another grand, if you do it.
Summit Hydraulics
Vendor Member
Hydraulic Kits & Components
Mar 2, 2023
65
81
Phoenix, AZ
summit-hydraulics.com
Hello, let us know if you have any questions about our rear remote kits! We would be happy to help!
SDT
multiple and various
Apr 15, 2018
3,325
1,103
SE, IN
Kubota sells packages with the parts needed to install rear remotes, though there is no single package for installation of three remotes. Such equipment is considered wholegoods so will need to speak with salesperson rather than parts department. Will need to specify type of valves desired. Expensive but everything needed included and will fit.
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
147
179
The Ville and The Farm (KY)
I have 3 Kubota rear remotes on my L3560 LE (2 regular and 1 float) installed by the dealer before delivery. They work well and I couldn't imagine having my tractor without them. I am sure aftermarket works just fine, but I wanted the Kubota ones. If you search YouTube, there's a good video on installing them.
anomad
YM2310D
Jun 10, 2021
101
55
Western North Carolina
That is a nice tractor! I'm jealous. What will you be running 3 remotes for?
SDT
Apr 15, 2018
3,325
1,103
SE, IN
I have 3 Kubota remotes on my L6060 as well as a Kubota third function.
No issues.
Summit Hydraulics
Vendor Member
Mar 2, 2023
65
81
Phoenix, AZ
Our Universal Rear Remote kit would work great for your tractor. The only thing you would need to complete the kit would be hydraulic hoses. https://summit-hydraulics.com/produ...ct-tractors-two-spool-three-spool-four-spool/ If you have any questions about the kit, you can reach us at (602) 806-7173 or at contact@summit-hydraulics.com
Amarillo
MX6000 w/ LA1065, tiller, disc, core aerator, box blade, shredder, Blast Sprayer
Jan 10, 2023
38
25
Amarillo, TX
