OntheRidge
I am looking for options to add weight to the rear of my L47. The manual specifically states not to use rear ballast with BH, which is on 90% of the time. However, when I use my rear blade, tractor is too light in the back. So, i could fill tires and ignore Kubota warning, or, I am considering adding the SpeeCo hitch with the weight hangers and 6 70 lb weights, from GoodWorks. WW fluid is now 6$/gallon, and I would need about 60 gallons. Or, I could use the weights, which would come off when BH goes on. The only downside I see is weights kind of hang out to the sides a bit. Anyone?? Thanks in advance, Cheers! Oh, total cost of the hitch setup would be around $1200.
