Helical pile implement
Chapstick
Kubota B21
Nov 13, 2023
Central NJ
What’s up guys. Been searching all over and haven’t found anything. Anybody have or have ever seen an implement for driving helical piles for Kubota ? I’m seeing them for skid steers and mini excavators but that’s it. I use to be a deck builder and just got turned onto these things. Nobody’s doing them where I’m at but man I’m certain I could create a market for them. It’s truly a game changer for the deck building racket. I would’ve been all over those things when I was building decks.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
790
687
E.
its a flow rate thing.
my buddy owns a business that installs
his little one needs 20 gpm flow and prefers a high flow pump closer to 35 gpm.
final installation torque something like 10,00 psi when I watched him put in a string of solar panel racks.
they sell manual ones but doubt getting the "bite" to be great enough to be much value is likely suspect.
5,726
You can just run it off a PTO powered pump/reservoir.
neighbour had some installed, real pricey ,but tight spot, couldn't drill a hole old school.
guy was a franchise company,that has custom baby 'dingo' machine.
Chapstick
Kubota B21
Nov 13, 2023
Central NJ
Wonder if I could rig this up to the pto ? Could get a stand-alone motor too.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,431
1,719
Kalamazoo, MI
The only helical pile unit I've seen was a self-propelled unit on tracks.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
227
67
NE Wyoming
A contractor at work just drove 98 of them with a Bobcat E55 mini ex. with a hydraulic head. Driven to 9500
ft/lbs. A pier for a deck would be considerably less I would think. I have also seen small ones driven with a
pto post hole digger.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Chance Anchors was one of the early players in the helical anchor market. I always thought that was a heck of a name for something you want to be at least 150% sure of. Even if it was the owners last name.
Soopitup
BX23S
Oct 25, 2018
369
164
New England
If you can mount it to a Skid Steer you can probably mount it to a newer Kubota.
Having the power to run it is a different story.
The PTO probably won't have the RPMs for this.
They're talking about a max of 3600.
5,395
5,726
yeesh, pump pushing 22 GPM needs a tank with 50 gallons of oil in it. The unit that did neighbor's pile sure didn't have that sized tank !
GrizBota
Apr 26, 2023
1,147
732
Oregon
NO.
And using Dynamic's claimed 90% volumetic efficiency 1.95 CID @ 3600 RPM is 22.5 GPM
Dsn
Hum. Using a 90% efficiency rate my math says about 27.35 gpm? Until you did it, it didn’t occur to me to check the math. Their number appears correct for 100% efficiency (clearly not realistic).
5,395
Ya caught me :mad:
Dont know what I did first time but my phone agrees with you this time.
I have put a number of the 1.95 CID Dynamic pumps on other tractors and that 35 GPM number started my Spidey Sense tingling.
You can also buy that pump for considerably less than $359. Going price from Burhan's has been $135 but I see its now up to $169.
3,099
Woman across the street had some setting issues, called ramjack to fix.
Here is what they used:
IMG_0023.JPG IMG_0022.JPG IMG_0021.JPG IMG_0014.JPG IMG_0010.JPG IMG_0005.JPG IMG_0002.JPG
GrizBota
Apr 26, 2023
1,147
732
Oregon
Interesting. Thanks for sharing.
I presume the red jack was used to load test each anchor individually and the reaction force is provided from the outer collar that has a bracket secured to the house foundation, using the dead load of the house foundation as the reaction force. Once the jack is pushing on the outer collar (as shown in the picture), it would seem it’s akin to lifting yourself up by your boot straps (e.g. no appreciable force is being applied to the anchor once the anchor has deflected that far).
This load test is similar to the name sake’s Ram Jack system where a metal pipe is installed by simply jacking it into the ground using the dead load of the house that a tributary area that lightly reinforced concrete (slab or stem wall) foundation can be relied up.
My criticism of these systems is the the factor of safety is very close to 1.00 since the spacing of the anchors is about what the tributary span/area of a typical lightly reinforced residential structure foundation is, say 6 to 10 feet. Typically a FS of 2.5 to 3.0 is desirable relative to the geotechnical capacity of the substrate.
I notice the jack only has one hydraulic line (no return line like a typical ram used for a load testing would have), but then I’m used to 250,000 to 2,500,000 pound load tests. Obviously one line will suffice for a 10-20 ton bottle jack.
If anyone’s interested, I found this International Code Council Evaluation Service Report on the hydraulically driven RamJack system (not the helical anchor system). Interesting how it says the spacing of the anchors is essentially controlled be either lifting (4.2.1, Item 5) or damaging the foundation. Although 4.1.1 states, in the 9th bullet that the spacing of the anchors must be addressed, if different than stated in 5.14, 5.14 states the anchor spacing (interaction) is outside the scope of the report.
ICC-ES Evaluation Report ESR-4331 02/2022
5,175
My L48 TLB has a 24.9 GPM rating.
Hyd. fluid capacity is nowhere near 50 gal.
