Hey guys,
Was just curious what you guys are seeing on your G6200 when it comes to battery voltage when running. My G6200 is a 1987 model and has roughly 1800 hours. I noticed the dynamo doesn't really raise the voltage until the RPM's go way up. Most I see when running at full throttle is about 13.6ish. At idle it's below 13 unless it was recently at full throttle and the voltage is gradually coming down.
Reason I ask is since a new battery was put in the tractor right before I bought it 2 years ago and now it's junk. Seeing as the new 51R batteries for the G6200 are stupid expensive, I'd like to avoid having to replace it again in the near future. Not to mention a new OEM dynamo is also over $200 and I don't want to buy that for nothing either, especially if the voltage I'm seeing is normal.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
