kubota gear shifter in neutral - moves foward slow and backward fast . cannot shift gearshifter
liberty
kubota LA481
Nov 12, 2023
DeRyuter
Kubota was working fine then put shifter in neutral. Now shifter is stuck in neutral position. Tractor will move forward in very low gear and backward in a medium to high gear. Cannot get shifter to move and is Stuck in neutral despite try8ing to shift. Clutch works fine. No oil leaking that I could see. Tractor has always been covered or indoor no rain. any thoughts on this. or how to approach?
8,191
Yea you'll get better answers if you tell us what tractor your dealing with.
Bmyers
May 27, 2019
3,389
4,123
Southern Illinois
Glide shift transmission ( 8 forward and 8 reverse)
Thanks, that will help those that are more familiar with that transmission to give better guidance.
3,737
Just a silly guess have you looked at the linkage ?
Nicksacco
Sep 15, 2021
698
412
Bahama, NC
This may help you: The L3010 uses the same kind of shifter mechanism as my L35
