Leinbach Disc Harrow
lakehouse_dreaming
L3901HST, LA525 FEL, RGA1258 tiller, RCR1860 rotary cutter
Nov 2, 2021
59
125
I recently got a used Leinbach disc harrow but the previous owner had converted it to a quick hitch and no longer has the original parts to convert it back. Curious if anyone has one like it and can give me the dimensions of the front "A" pieces that go from the 3pt pins to the top link that I am missing.
IMG_7084.jpg output_image1699717218028.JPG output_image1699717227983.JPG output_image1699717238686.JPG
2,601
I think you need to replace the triangle that was on the implement
This site has the dimensions
I imagine the parts can be purchased from the manufacturer if you contact them directly
5,572
Your most likely going to have to use the standard dimensions as noted by @Russell King and fabricate something. Unless you’re using a Quick Hitch with it, 3 points are pretty forgiving on precise dimensions so close is close enough.
I have a few Leinbach implements. They’ve been out of business for many years. They used to have a manufacturing facility in East Bend on Hwy 67 on the north side of the Yadkin River and a sales/repair place on Hwy 67 (Reynolda Rd) in the edge of Winston-Salem, about 15 miles apart. As I understood it (and could be wrong) one side of the Leinbach family ran the Winston operation and another side ran the manufacturing. The Winston operation shuttered first with the East Bend group shutting down a few years later.
Oddly enough I did see a website for Leinbach Implement but it was written like English was the author’s second language and anything past the home page went to some weird mess with that Chinese sort of pictograph writing. Suspect you’re on your own with that project.
old and tired
1,919
1,297
I'll head out soon and take photos... I have Leinbach implements, all used except the PHD (which was $375 with a 9" bit). Bought it from their Winston-Salem location when they were open... way back when. I miss that place...
5,187
lakehouse_dreaming
Nov 2, 2021
59
125
lakehouse_dreaming
Nov 2, 2021
59
125
Unfortunately the manufacture is out of business. I did find a website for them but when you click the link to look at different implements it redirects you to the EA website. I know EA used to sell Leinbach but not anymore.
lakehouse_dreaming
Nov 2, 2021
59
125
I am needing the part# 6 in this diagram. This is a King Kutter diagram but if anyone happens to have a Leinbach 300S-2018 and can tell me the dimensions that would be awesome.
Lencho
B7100hst
Jan 21, 2017
445
115
NM
I will have to remove the yellow piece and add pins but it is missing the supports that go from the pins to the top link. I think I will just have to try and make some out of some flat bar.
I bet you can make those parts. Go for it!
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Given that this implement doesnt require a driveshaft, i would simply buy this thing for $36 shipped and weld it directly to the bracketry you have left there.
5,187
THAT is being sold at a GREAT price.....the OP should Go For it!
