Unfortunately the engine wont start, or stay running if we start it by spraying fuel in air intake.If the engine is running, it's easy to figure out which injector is affected. Simply loosen the line fitting on top of the injector, one cylinder at a time. If the engine rpm drops, then that injector is doing something. If it doesn't, you found the bad one. Now leave it cracked open for a few moments to ensure it is fully bled. If the rpm picks up when you retighten it then you "fixed" it.
Sometimes the little buggers just want more bleeding.
Randomly/counter intuitively though the closest the engine get to starting on it own stream is when we loosen the nut of the line to one of the injectors from the pump (to attempt to bleed), then when we tighten it again it goes back to struggling. This particular line was struggling to get a flow of fuel. We see bubbles at this location on b the other two lines.
This is making us think there is something wrong with the diaphragm at the bottom of the pump.
