DepositGuy
Kubota L5030 with cab, 6 foot Landpride Rotary Mower, Kioti LK3054, too many att
Hi guys. The saga continues. I got a decent price on a Kubota / Bradco 509 backhoe attachment which I hope to pick up tomorrow. As you know, the 3 point hitch arms must be removed to use the backhoe. My left arm detached easy enough but the right side looks like it got a hillbilly repair. The arm cannot be removed unless I cut both sides.
I'm looking for possible repair options so I can remove the arm and re-install it anytime I want. I've got my own thoughts on repair but maybe someone has a better solution.
The 1st pic is the left side for getting an idea what it should look like.
The next 2 pics show the welded repair and after I cut around the bolt head and removed it. The bolt wasn't screwed in, just slid into place.
The last pic shows a threaded-something used instead of a solid pin. It must be hollow as the bolt I cut out slides inside it.
Any suggestions would be appreciated.
