Kubota L3710 dip stick location?
unioncreek
Kubota L3710 GST
Nov 1, 2023
49
WA
Kubota tractors are new to me, just purchased a used L3710 this last week. I’m assuming the dipstick is the little rubber knob lower on the drivers side of the engine. Do you just twist and pull it out? Don’t want to wreck it.
can someone recommend some good YouTube videos on maintenance and such for the Kubota?
Thanks,
Bob
Flintknapper
L2350DT
May 3, 2022
1,764
2,216
Deep East Texas
No twist, just pull it out, the rubber 'knob' acts like a stopper (interference fit) to seal the opening. It is purposely small and tucked away....so as not to snag on anything and be pulled out.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
"Dipstick Location"
Ask the Operator. Oh, wait 😳😂
unioncreek
Kubota L3710 GST
Nov 1, 2023
49
WA
Thanks. I just wanted to make sure before I try and get it out.
is it possible to get an owners manual anywhere? Or are they not worth it. I do have a digital copy of the service manual.
Bob
2,965
Bob
Not sure about the operator's manual, but you can download the workshop manual at kubotabooks.com
Here is the first part. The second part is there also. hopefully the link will work. If not, you can go there and check it out.
Edit: I see you mentioned having the service manual...if that is the workshop manual, sorry...but maybe the link will help someone else in the future...
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
you should be able to down load the owners manual from the regular site, just find your tractor and it should be listed there with the brochure. Just checked, seems to be a old model, so just google your model, it will take you to kubota and you can down load the manual there.
Trimley
Jul 25, 2023
1,185
877
PNW-WA
Couldn’t find the owners manual on that site.
Bob
Perhaps this may be an option, if nothing is found.
It seems your manual needs to be purchased.
Edit, this link was removed.
6,356
I'm still searching.
Edit, this has a download option
Did you look at the manual your pointing to?
It's just for the cab, nothing else, pretty much worthless.
