Rear electrical connection
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Dan is correct but you must look carefully. It's rather a small connector taped into the wire bundle there. It's on a ten amp circuit and there is no switch. It's hot whenever the key is on. It is a standard connector but you can't get it from Kubota unless you purchase the whole work light package unless things have changed.
7,322
I have a bag full of the connectors - cost of postage will get you one or more.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Running a heavy (fused) power wire to the rear of the tractor provides unlimited possibilities, (lights, fans, small winch, jumper cable, 12v fuel pump/bulk tank, ect)
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
I did a similar install as i7win7, although a bit more modest. I wanted a fuse block back there that I could take different switched circuits off of. My install was for a max of 20a draw. It powers all my added led lights, snowblower chute rotation and deflection, and an automated ssqa open/closer.
The (cheap) 40a relay powers the fuse block whenever the key is on (fed from that aux light connector).
7,322
I have the very same components sitting here right now. Mine will be 40A and everything will be housed in a polycarbonate enclosure with a gauges, switchs and multiple 12v outlets on the exterior. How hard or costly would that have been for Kubota?
SCVandy
L225
Dec 31, 2013
Waverly, NY
i need a connector that will be like a cigarette lighter thing so I can plug in my light. is there such a thing and if so, what is it called so I can order one? Thanks
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
I install those connectors in all my vehicles:
They are referred to as "12V DIN" or "12V Hella" or "12V BMW motorcycle" connector.
They give better contact than cigarette lighter connectors.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
You might consider something more weatherproof like SAE plugs or some flavor of automotive connectors of your tractor will see humid/corrosive conditions. Can also double as a battery tender connection if the connection is "always on.'
3,132
There are panel mount SAE ports also to make it easier to use, if you have a place to mount it.
