L4060 pulling disc harrows
bsd
L4060HST-LE, IH S300 ('55)
Jan 18, 2022
41
I realize my tires and traction will account for a large portion of the answer
I have a 12 acre field that I've been leasing out to be farmed. This year I want to convert to pasture.
The farmer presently has field corn, not an ideal crop to convert from, but I'm 65yo, so I can't wait another year of rotation to have beans, then wheat before conversion, I have to do it now. We want critters than need pasture.
So, I've been advised to get out asap and run disc harrows to cut up the corn and then plow to turn the corn into the soil.
Since this is theoretically a one-off operation, I'm inclined to rent or hire help with a larger tractor, harrows, plow and just write a check.
But, I was wondering could my L4060 do the work? Granted the DH will not be 26' wide, but maybe 8'
Any references?
Bmyers
May 27, 2019
3,486
4,396
Southern Illinois
I believe you would be looking more at a 6ft disc harrow vs 8ft or larger. A 6ft harrow, you should be able to pull it at 4 to 5 mph. I think a larger harrow with 40hp tractor and R4s will struggle.
Is it better to hire out the job? It depends, how much time do you have, how much is the cost to have it hired out? Almost any problem can be solved with money, the question is how much money.
PS-if you look at LandPride, I believe the have an implement matched chart, actually here is a link to it
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
My 40hp Massey on R1's had all it wanted with a 7ft disk, so a 6ft would be good. It also depends on the ground. wet clay vs dry sand.
2,391
You may want to get it leveled with a land plane to knock down the furrows before you get grass growing on it.
4,335
If it is a one time thing,, get someone to level it out and disk it, and then you know it is done and you dont have to worry. Wish I was 65 again !
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
819
726
E.
If me I would do it myself.
Your tractor is capable of making the work with the right equipment. Would need to know soil type but 5'harrow (+/-) depending on soil conditions is realistic followed by a 18" plow. If me multiple passes with a 5' disc is what I would do and forget about the harrow/plow recommendation.
Other questions are :
- do you have the time(I'm retired so for me I can make tractor work all day and almost all night, rinse and repeat all week long).
- do you have the equipment already. If you have to buy or rent for a single use it can get expensive fast.
- do you have a local (like a guy like me) who makes work in the area for next to nothing. Often feed me and I am happy to put in a full day. What would their cost be versus your time + equipment cost.
Cheers and sounds like a very doable project.
bsd
Jan 18, 2022
41
I have a land plane, that I just bought to level my driveway. I was told disc then plow. And you're saying follow that up with planing?
2,391
If you plow it you’ll have furrows probably. Drive across your field and you will have to go slow even on a tractor. A land plane will make it flat.
Can you drive across the field today and see what you think about doing that to deliver feed or hay or to mow the fields?
It is your call on what you want to do really, we just give thoughts for you to evaluate.
4,335
bsd , Im sorry my mind goes faster than my fingers can mash the keys,,, Yes have someone come and disk it, in both directions if you can, and then if it is not to your liking then run your land plane over it. And if I may ask what kind of critters are you planning to put there?
bsd
Jan 18, 2022
41
That applies to nearly everything one reads online
Life's an on the job learning experience, and now I'm learning very basic farming.
Right now the land is close to flat, not perfect though. It looks like a field looks after field corn has been harvested. It's very messy with stalks, cobs, detritus. I'm in SE Michigan, flat.
I can afford to buy a used, larger tractor, but if this truly a one-off and then going forward I'll be doing general haywork, then I think the L4060 will be good enough.
The farmer who has been leasing was given exceptionally low lease rates, and he has the equipment, so I expect he'll either loan me the equipment, or just do it for me, likely the former.
He says my field is too wet for Alfalfa so I'm trying to find someone who can install some tile for me.
Any suggestions for tile installers willing to travel, I've got 10 acres adjacent to ag drain ditch, quick one-two day job.
bsd
Jan 18, 2022
41
Donkeys, horses, goats, with maybe after each..
Changing my name to Traps
GrumpyFarmer
4,312
Good day. Have you reached out to your extension service / farm sercice / usda / etc. (if you have wooded acreage don’t forget the state forester). Typically they are a wealth of knowledge and very helpful. I’d try the extension service first assuming you have those in your area. I’d start there and I bet they can give you some ideas, put you in contact with correct office or some service providers and maybe even share some idea on funds / grants that might be available to you. I am not sure what resources are available in your area, but at least in Ohio, you can simply give em a call and they will come to your property walk it over with you and make some assessment /share some thought…it’s been very helpful in my experience. Good luck.
bsd
Jan 18, 2022
41
Thank you, I'll have to take a look and see what we have in Michigan.
3,471
2,046
If you're doing it for entertainment, get a couple of miniature donkeys. They're the most fun.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
I wouldn’t disc before plowing. I run a bush hog over stalks to chop them up in the fall then chisel plow it all under. Then I don’t disc until spring and it usually takes me 3 passes with a disc and using a drag harrow behind disc on last pass to create a good seed bed for whatever I’m planting in spring. I also run a cultipacker behind any planters or drills that don't have firming wheels built into them. If I wanted to plant winter wheat or grass I’d skip doing any kind of plowing. Mostly because running over plowed ground that hasn’t settled down from a good winter is rough on your body (if you can manage to tolerate it at all) while going 4-5 mph, which is the speed you’ll need to be for the disc to do it’s job.
p.s. You can skip the bush hog if they used a chopping head on the combine. My JD6620 doesn’t have the HP to run one so I have to bush hog.
p.p.s. It was all my M5-091 wanted to do pulling a 14' tandem heavy disc in sandy loam before I fixed the Tier 4 issues. ;)
bsd
Jan 18, 2022
41
That's current work in progress, just picked nice, used, run-in for mini donkeys.
Presently searching for clean, healthy, affordable mini donkeys.
2,391
There may be some sort of “donkey rescue” that may have animals that need a home.
Here in Texas there is usually some rescue organization that is willing to evaluate your situation and help you get the animals into a safe place.
9,298
You don't want alfalfa for a pasture, it won't last 1/2 a year.
You want grass for a pasture, it will recover quicker.
You also don't want them on it for a couple years to let it get established.
And when you do rotate the time they are on a section.
And pull them off of it before it starts to get blighted or muddy!
3,471
2,046
I was introduced to the mini donkeys, along with a bunch of other animals, while volunteering at a horse rescue near my home in west Tenn. They had the friendliest 'personalities' and I had to laugh when they brayed about two octaves high.
I would just advise bsd to make sure they have adequate shelter. These small animals may be more sensitive to cold than the full size equivalent, I'm not sure.
