Looking for a new trailer...
06B3030
Sep 21, 2015
170
233
MA
Good Morning...I'm looking for a trailer to transport my B3030 tractor. It had a loader and backhoe, combined it's just under 4K pounds. The trailer I'm looking at is a new 18' RICE Trailer. It has a GVWR of 7K. I'll be towing it with a new Silverado 1500 with the 3.0 Duramax diesel, which has a tow capacity of 9K.
I rented a trailer back when I bought the tractor, and that's the only time it's been towed. Just wanted to get any thoughts/recommendations on this before purchasing one.
Thanks,
Glenn
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,444
1,740
Kalamazoo, MI
Trailers are just like shop buildings. Figure what size you absolutely need, then go bigger.
Reactions: 6 users
Jchonline
599
Red Feather Lakes, CO
Thanks,
Glenn
You will be really close to your GVWR on the trailer with that machine but should still work. Probably need to back it onto the trailer (backhoe weight toward tongue a bit). Check your tongue weight on the hitch as well, but at 9k you are probably fine.
That tail on the trailer is really low to the ground...dont back up unless you know exactly what is behind you! I also dont like ramps that dont have support under them (outriggers on trailer or welded feet on ramps). Trailer pops up in the air if you dont hvae that...you could also use some 6x6 blocking.
Advise to go bigger really isnt relevant beacuse your truck won't safely pull it anyway.
06B3030
Sep 21, 2015
170
233
MA
Thanks.
I was going to fab supports for the ramps. I'll be ~1K under the max, and should be ok. As you mentioned, moving up to the next size trailer, 10K...I'll be over the tow rating of the truck.
5,185
Thanks.
You may keep the trailer FAR longer than the truck.
I would absolutely go for the 10K trailer.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
175
183
If it were me, I would consider upgrading your 3500lb axles to 5000. If you ever go up in tractor size, (almost everybody does) that trailer is going to be maxed out.
5,185
Yup........two 5,000 lb. axles makes it a 10,000 lb. trailer
Jchonline
599
Mine is a 14k and I still cant haul all my stuff around...ugh.
Tughill Tom
B3200
Dec 23, 2013
1,404
1,932
Turin, NY
What others have said, go up to 10K LBS and get brakes on both axels. I have a 18ft 10k and wish I went up to 20ft.
6,383
Thanks.
That's a sharp looking trailer. If it were me, I get a 10K 20 footer (note, you can de-rate the trailer in most states) and register it for your tow capacity. Very easy (in most states) to do....that's what I did as well.
5,535
I’d go with 10K trailer and brakes on both axles. That and be realistic about max length of tractor and any implements. A stubby little tractor can get really long really quick with a loader and bush hog. I run a 14K trailer behind a 10K truck. No issues other than I’m limited to 10K gross trailer/cargo by the truck.
GrumpyFarmer
4,647
Thanks,
Glenn
Good day. I am not sure this helps or not, but I don’t believe there are any clear cut standards for tow ratings for commercial trailers…so there is definitely some buyer beware…crawl under three different makes and you’ll see three very different things.
To each their own…everyone has different load strategy…you can see that just seeing how people load their stuff. I think having a little extra length on the deck makes it a lot easier to balance your load for different configurations of whatever you may be hauling.
I also think the fold down MaX ramps are slicker than a cats ass…again to each their own if you want to spend for that or not, but I would not buy another trailer for my tractor with out them. I’d also offer that if you are getting or considering those you can tow the trailer with them in the 90 degree position, but if you do want or need to fold them down, sometimes that will change your load strategy and having a little extra length allows you to pull tractor forward to fold them down and then you can back up if needed to balance the load.
Anyway those would be two things to me worth considering. In general, same as the machine, but once cry once (buy more than you think you need). I hope this helps 🥃
4,616
Glenn, you are describing the almost identical situation I am in. Except, I had the trailer before I bought the tractor. Its a 16 foot with dual 3500's.
My machine with loader is about 4k, with the hoe on it's just under 5K. I get along,........ but I would much rather have the "extra" capacity for the small dollar difference of the initial outlay of cash.
The way I look at it is this; Just because you are towing a trailer capable of more weight than your truck is rated at, does NOT mean you have to load it up that heavy.
There is piece of mind in having your trailer loaded up, with "room to spare", so to speak.
I also agree with the above advice regarding the brakes. Get the good stuff, you won't be sorry.
will721
LX2610, Ford 2n, Ferguson TO20
Jun 6, 2023
179
187
Quad Cities Area
I'll be the devils advocate here. So long as length isn't an issue I think you'd do just fine with that trailer. By length I mean how it results in weight distribution. Having the backhoe might make a short trailer off balance. However I would as others have said upgrade axles for better brakes and strength.
A common misconception is that a 10k capacity trailer pulled behind a truck with a 9k max tow rating is a bad thing. Just because the trailer is rated for 10k doesn't mean it weighs 10k. You don't have to, nor should you max out the capacity of a trailer. Doing so increases wear and tear on the trailer itself, plus negates the effectiveness of the brakes.
The maximum payload capacity of a trailer has nothing to do with the tow capacity of a truck. What matters is actual weight of the trailer empty. That number added to the payload you intend to haul is what makes up the gross weight. Thay gross is what you have to make sure is within tow capacity.
5,995
That is a NICE trailer and the only upgrade I'd do is add BACKUP LIGHTS to it.
It has brakes on BOTH axles, something that you need. Pulling a trailer is easy, it's STOPPING that can be ,well, 'challenging'.
Since you're 900# less than being 'maxxed out', you'll be fine and there's no actual need to go bigger.
I routinely max out my 7K dumper behind my F150. Zero issues. yes it takes awhile to get up to speed and to slow down..just the 'nature of the beast'.
06B3030
Sep 21, 2015
170
233
MA
THANKS EVERYONE for your input!!
I decided to go with the 10K trailer. Having the 12" vs 10" brakes and overall heavier suspension, is worth the extra $$. Just the better braking capability will be worth it. Besides I'll be towing the tractor for MA to NC in the spring, so having the heavier trailer will be safer overall.
Thanks again!
5,185
Thanks again!
Excellent decision !
Those are the very reasons that I bought a 14K rated trailer.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,189
3,493
Thanks.
Not sure about where you live, but most states don't care what the GTW rating is. Most will never bat an eye if you load it to 10 or 11k because you aren't commercial.
Personally, I would go to a 10k trailer. It will be there for the next tractor, or for some other purpose you need. What if you want to take the grapple and box blade along with the bucket and rotory cutter? You'll be over the capacity then. Just think forward to what you may di in the future.
On the plus side, used trailers have good resale if you take care of them. So if you go with the 7k and need to upgrade, it should be easy to sell for good money.
6,383
Thanks again!
Congrats...and good choice.
Before you pull the trigger, perhaps inquire about fork carriers....something like these. You may be able to do them as a small add on....
