M9000 shuttle shift cable melting.
MITCHDEMP
M9000, BX24, KX161-2
Nov 4, 2023
Alabama
The shuttle shift cable on my M9000 broke. I purchased a new cable and we got about two hours on it and it stopped working. We took the floor plate off to check it out and the cable shelf had melted and the cable froze up. We replaced that one and made sure everything was routed properly with all brackets. Same thing happened again.
Any ideas to what is causing this?
2,921
1,383
Check the cabin ground strap to see that it is not corroded or broken. It is I'm thinking at the RR of the cabin to the rear-end housing.
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
611
808
Ontario, Canada
If you have poor grounds, the shift Cable may have changed its identity from a shift cable and is now a ground cable, which is insufficient and burning u 🔥
MITCHDEMP
Nov 4, 2023
Alabama
It isn’t an electric cable. It’s a steel cable and the insulation/sheathing is melting and binding the cable.
2,921
1,383
If the cabin ground is not making a good connection, the current looks for another path which it commonly will find in a control cable. The control cable gets hot from the current flowing through it and it melts the sheathing. It is also possible the control cable has rubbed through a positive battery cable but you probably would have noticed that right off.
You need to locate your electrical problem to keep from cooking the control cables.
