Tractor is running away with itself
Yooper
3901 LA525
May 31, 2015
1,663
806
NE Wisconsin
Take a look at the intake side of the turbo. Possible bad oil seal feeding oil to the cylinders.
Randolph63
M108x
Oct 30, 2023
10
Oklahoma
Thanks I have checked both of these things
after about an hour the rpm’s start climbing slowly till it hits the max
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,268
174
Coyote Flats,Texas
Do any fault codes appear on instrument panel? I'll guess common-rail electrical problem.
Yooper
3901 LA525
May 31, 2015
1,663
806
NE Wisconsin
Now I’m leaning towards an issue with the governor. Not familiar with your engine but I assume it’s a mechanical governor?
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,268
174
Coyote Flats,Texas
My guess from viewing M108X parts catalog is that engine speed(rpm's) is electronically controlled because I located no mechanical governor in PC
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Hard to tell from the brief and short replies from the OP. Doesn't sound like a true run away. A run away isn't gradual. Not in my experience. Unless you call 5 seconds gradual.
If he or she was a little more engaged it may help. Video is a real easy thing these days.
Randolph63
M108x
Oct 30, 2023
10
Oklahoma
when baling and the throttle is set after about an hour rpm starts climbing.
You can cut the throttle back but it keeps climb till the redline.
once it cools down it acts right again for a while
4,088
Is the throttle lever actually physically moving?
Could it be "vibration" making it creep up?
5,800
re: once it cools down it acts right again for a while
Sounds more 'computer' related that mechanical. Locate whatever 'computer' boxes there are and blow ALL the dust,dirt, mud far,far away. 'Baling' is a dusty operation !
When electronic parts get warm or hot, they can change their value. That changes signal to computer, and bad things can happen.
The fact that 'when it cools down it's fine' was my clue.
Yooper
3901 LA525
May 31, 2015
1,663
806
NE Wisconsin
Oil getting past rings as it heats up? A compression test cold versus hot could rule this out.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Sure sounds like a fuel supply issue, too much as opposed to the more typical too little. If the oil level is not decreasing, it sounds like electronic gremlins.
Randolph63
M108x
Oct 30, 2023
10
Oklahoma
Latest update the alternator Shorted out catching the tractor on fire
i got the fire put out but it burned the wiring so I’m repla one wire at a time so I won’t get confused a Kubota mechanic told me that this might have been my problem. We shall see unless I go crazy first
4,088
Wow that sucks man.
Good luck with the repair.
