L175 will not move
ALAN BRADSHAW
L175
Oct 28, 2023
Rutherfordton, NC
I have a L175 that seems to be in some gear but, will not move. If the clutch is let out, it will bog the tractor down. I have tried high and low range, as well as forward and reverse. If I depress the clutch, it will not roll although when this started it would so I feel sure it is not a brake problem. Any thoughts??? I really need the tractor out of my driveway.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
673
282
Herald Calif.
I would think it is stuck in two gears. You need to remove the top shift lever cover and line up the shift rails.
8,899
Jack up the rear of the tractor and try and spin each wheel separately.
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
Last 175 I had one of the shift forks broke and it hang in the gear set that was floating back and forth. As said pull the cover, drain the oil if you have to, and do not lose any balls or springs!
