BH70 Backhoe
geraldrobinette1360@gmail
BX25 and new B2601, FEL, BH and MMM
Apr 11, 2022
The dipper pin is shearing the bolt. Anyone having this problem. It is like the pin is welded to the dipper. The backhoe works OK but eventually the pin and the boom will have to wear causing bigger problems
3,676
make sure that the bolt is not tightened down. It should have a nylock nut on it as it needs to be able to move freely.
lynnmor
B2601-1
May 3, 2021
1,444
1,159
Red Lion
Often the grease fittings are plugged with paint, make sure that grease is flowing to the pin. Please specify which end of the dipper you are concerned with, it does sound like the top end. If the bottom, do you have a thumb? Make sure that the dipperstick doesn't hit the boom in the corners when fully extended, mine did just that so I relieved the boom corner radii with a carbide burr. You might want to remove the bolt and try to move the pin with a punch and light blows with a hammer, if it is tight you need to find the cause such as galling or defective parts. These backhoes were produced in Georgia by folks that don't deserve a job.
