B1630 Bucket cylinder grease fittings.
Tchara
B7200
Aug 31, 2023
9
I started greasing my B7200, and noticed there are grease fittings at the top and bottom of the right cylinder, but no grease fittings on the left side. It looks like there never has been. Is this normal to only have grease fittings on one side of the bucket cylinders?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
Normally there are grease fittings on each end of each cylinder. You may have to reposition the bucket to make them accessible or they may be on the end rather than the side but should be somewhere. You may need to check the manual for locations or even ask the dealer.
5,619
B1630 loader on my B7200 has zerks on all cylinder pins.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
No.
Someone probably replaced that cylinder and didn't install zerks. You need them
But look really close for the zerks, and for a plug in a predrilled hole. Check top and bottom, before drilling and tapping and adding zerks.
Edit: Sometimes they'll be on the outside pin connection on the loader arms.
2,310
The cylinder may be mounted incorrectly so compare it to the other side?
I guess it could be a Right hand on the left side thing?
PaulL
2,614
1,585
NZ
Sometimes the zerks get broken off. If it's not that clean you have to look pretty hard to see the holes.
