Hydraulic Remote Part Numbers
iggy913
9
Moyock, NC
Ladies and Gentleman,
Will be taking delivery of an L6060 Cab model tomorrow!!! Something I didn't option but I plan on installing fairly quickly is a set of rear hydraulic remotes.
I believe the tractor has provisions for three additional outputs, but I wanted to clarify the part numbers necessary here for the install:
L8393
L8394
L8396
Those numbers are for the actual levers and associated hardware, I'd need one of each.
Additionally I'd need the three valves which look to be the following:
L8308: Standard dual acting valve
or
L8309: Float detent valve
Does that seem correct?
7,104
L8393
L8394
L8396
or
That's only part of the picture. Those are the actual valve segments and nothing else.
Prepare for a little sticker shock. You will also need the 1st, 2nd, and third lever kits. You can find those numbers on the Kubota parts site. I suspect the remote outlets are also sold and priced separately.
Oops - did not read carefully. You have the basic idea but you need to verify those handle kits include the hoses and remote outlets.
7,104
L8393
L8394
L8396
or
L8396 is the base kit. You only need one. Them you need the three valves, and the 3 lever kits.. Couplers seem to be included in the lever kits.
iggy913
9
Moyock, NC
Thank you all for the replies. I've gotten answers back from two Kubota parts suppliers now ranging from $2300-$2900. For part numbers for anyone interested I was given the following, for three valves two normal and one float:
L8396-620: Base Kit & 1st Lever Assembly
L8393-620: Second Position Stacking Kit
L8394-620: Third Postion Stacking Kit
L8309-620: Float Detent Valve Assembly
L8308-620: Regular Valve Assembly x2
7,104
Parts list looks complete and the $2300 price is better than I would have expected. Less than I was quoted 3 years ago for the same configuration with a second float valve on a L3901 How does that price compare to current MSRP?
You can get the MSRP by going to Build my Kubota site and configuring a machine with those options.
iggy913
9
Moyock, NC
Looking online at the Build Your Own Kubota page the pricing is about the same:
The three Lever Assemblies/Stacking Kits are $1491.
Double Acting Valves are $294 each
Float Valves are $369 each
Not sure if that includes installation if you were buying it with your tractor purchase. I was just glad to find the part numbers so I know what I need now.
Poophead
Kubota 3901hst
Mar 6, 2016
15
weleetka,oklahoma,usa
