SSV65 Electrical Issues
BirdieBalls
2018 SSV65
Oct 16, 2023
Middle USA
I bought a 2018 SSV65 with 1200 hrs. I got it cheap because there was a 021 code indicating 5v short. I’ve now removed the wire harness and pulled the pins from the ECU that I suspect to have a short. I have it hooked up to a 12v battery and now I get a 023 code which the WSM says is from attempting to jump from a 24v source.
when I test voltage on various circuits I get unexpected results. The fuel sensor currently shows 0.7volts being sent to the sensor.
I’m scratching my head on this one.
jaxs
B1750HST
Jun 22, 2023
1,065
803
I've not made it secret I think Kubota hangs unnecessarily complicated electronics on their equipment. Even their dealers can't fix the computers so just replace them,I doubt you'll find any shade trees that have figured a way around it.
BirdieBalls
2018 SSV65
Oct 16, 2023
Middle USA
It’s hard to disagree. There isn’t very good documentation or detailed explanations of the electronics to be found. Even the WSM isn’t complete and has numerous errors in connector numbers.
BR928S4
SSV65
Mar 21, 2024
I am having the exact same problem with a 2017 SSV65. Error code 021. Did you ever find the the problem and fix it?
BirdieBalls
2018 SSV65
Oct 16, 2023
Middle USA
I haven’t figured it out yet. So far I have replaced the main ECU, ECU plug and the accelerator dial. I have found that if I disconnect the accelerator then I get a 023 code. As soon as I plug in the connector I get the 021. The new sensor acts the same. I dont seem to have a short on the accelerator sensor wires.
What are your symptoms?
BR928S4
SSV65
Mar 21, 2024
I determined that there was no +5V supplied by the main ECU. There was no short in the harness.
The accelerator dial should have +5V on pin 4 and ground on pin 3. Pins 1 and 2 are the sensor outputs to the ECU. Check the resistance to ground on all pins. Only the ground pin should show low resistance.
If you unplug the ECU connector all pins should have high resistance.
After replacing the main ECU I was getting +5V again and my problem cleared up.
The other two sensors using +5V are the Aux thumbwheel, on the right handle ,and hydraulic oil pressure transducer.
Someone had cut the wires on the Aux thumbwheel and I think that shorted the +5V and eventually killed the supply in the ECU.
Jack Rotts
SSV75
May 3, 2025
Wisconsin
BirdieBalls, what did you ever figure out? I also have low voltage (0.78v) going to my fuel sensor. Found your post from a couple years ago as I researched. Thanks!
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
271
364
upstate, NY USA
@Jack Rotts,
FYI:
BirdieBalls
BR928S4
Both of the above members haven't been active here for about 362 or so days.
If you "click" on a members user name, it will tell you the last time they posted.
You'll have a better chance figuring out your issue by starting a new thread yourself.
BX25D Rookie
Mar 21, 2019
271
364
upstate, NY USA
@Jack Rotts,
I now see you have already started your own thread.
I wouldn't hold my breath waiting for those other two members to respond. :)
BirdieBalls
2018 SSV65
Oct 16, 2023
Middle USA
I still haven’t solved this. I had to step away from it to finish other projects. Back at it now. Hopefully with better luck
whatsupdoc
L3302
Jul 9, 2024
173
198
If this is a 5v reference coming from the ecu use the wiring schematic and find all the components that the reference voltage is provided to,
Disconnect them all and check the voltage key in run engine off.
If there is no 5v at component connector pull the ecu connector key off engine off and check the 5v wire for short to ground.
