moejr New member Equipment B2150 Apr 11, 2021 14 5 3 Mendon Ma. Oct 15, 2023 #1 How "stiff" should the speed control lever be on my B2150? Seems to take some effort to move but could be normal? I don't use the tractor a whole lot so maybe it needs to be lubed?
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,746 2,551 113 Bedford - VA Oct 15, 2023 #2 I would definitely start with the lube - then look at the linkages. Reactions: 1 user
R RCW Well-known member Lifetime Member Equipment BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU Apr 28, 2013 9,159 5,261 113 Chenango County, NY Oct 15, 2023 #3 85Hokie said: I would definitely start with the lube - then look at the linkages. Click to expand... My Speed Control Lever always works better with some lube. Just greased it the other day. Last edited: Oct 16, 2023
moejr New member Equipment B2150 Apr 11, 2021 14 5 3 Mendon Ma. Oct 15, 2023 #4 Good point on the linkage, I'll check it out & lube all the moving pivot points.
moejr New member Equipment B2150 Apr 11, 2021 14 5 3 Mendon Ma. Oct 22, 2023 #5 Checked linkage (ok) & lubed all the pivot points ..... Bingo! Working like new. Did the same to the bucket & backhoe valve controls. Reactions: 1 user
