BX23S can't lift front bucket loaded with gravel
2021 BX23S Home resort
Bx23s
Oct 14, 2023
Ontario, Canada
I have a bx23s and purchased new in 2021. I am moving a load of gravel, but can not lift front bucket when it is full of gravel. What is lifting limit of stock bx23s with la340 fel? Should it fully lift a full bucket of gravel?
Garvini
Kubota b26 hydraulic thumb pallet forks
Apr 4, 2022
24
17
Hingham, Massachusetts
it should lift it...your bucket holds 5-6 cubic ft... dry crushed stone is about 100lbs per cubic ft... your loader is rated at about 750lbs...are you raising the throttle enough?
Hkb82
Nov 17, 2021
387
312
Ontario Canada
Those limits are at your FEL pin not sticking out the front or with a full bucket of gravel. Also full bucket and heaping bucket are two different things. Easy fix is to take a bit less of a bucket. 6cubic feet plus bucket weight is gonna put you real close to the limits of your bx or should I say did put you. Another thing to consider is the type of stone your working with plus is it dry/wet. To me this sounds more like you found the max and less like something is wrong with your bx.
Don’t forget the weight of the bucket.
4,897
RPM needs to be 2500+ and there's a big difference in wet pea gravel vs dry 3/4 clear....
Bearcatrp
Mar 28, 2023
619
335
Minnesota
High RPM’s and a ballast box on the back maxed out on weight. Should lift with no problem. Let me guess, your back tires came off the ground trying to lift a full buck.
3,545
2,001
What Kubota is selling in the brochures
SCUT
CTL
I see a difference. Do you see a difference? Which picture best matches your machine?
4,897
top one, except I got rid of the ROPS and BH has never been off
wonder how long it took them to stage that gardening scene ??
miketrock
163
Pa
You can get a pressure guage and check how much hydraulic pressure you have ... sometimes from the factory they dont have as much hydraulic pressure as they should. You can get shims from a kubota dealer and raise your hydraulic pressure a little if needed.
GibbyESS9
2020 Bx23s,BX2672 plow, Titan Forks, Land Pride 48” BB, FEL, Bestco Flail mower
Sep 30, 2020
89
121
Blue Point NY / Newfoundland PA
I move a lot of 2a gravel/stone with my bx23s. Trails and driveway maintenance. If its wet, you definitely know the difference. I can NOT heap the bucket and raise it to dump in my Polaris Ranger. Even load yes.
You just have to know the limits I guess. Still love my bx23s.
Gibby
5,066
The little Kubota is OK,...... but the driver looks better!
Bx23s
Oct 14, 2023
Ontario, Canada
Thanks. Full bucket. Still happy with bx23s. Guess it just take me a little longer to move the 2 truckloads of gravel.
Bx23s
Oct 14, 2023
Ontario, Canada
Thanks. Will do this. Dealer is a 2 hour drive away, so I need to plan a day for shopping trip.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,106
804
Wellsville, PA
BH on back, back tires didn't lift. Could curl bucket but not lift.. Spilled some out to 3/4 full and lifted to move gravel
I've never had that problem with any of the BX tractors I've had even the old 2005 BX23D I have will easily lift a full bucket of anything without any problem. Below lifting a heavy log with clamp on forks.
4,897
yes, it is a lite 'light' in lifting.
the spec of 700#(?) is AT the loader frame AND include the weight of the bucket,so realistically about 500# 'payload', so always fully curl back to get max.
if you're moving patio stones, put them in vertically not laying down,you can carry more.
when you decide you need pallet forks,get the lightest ones possible. I have HLA 900# unit,which is overkill and NO need for 2000# forks.
2,778
Anything can be overloaded I guess.....Hahahah
