Rowan Mays
B7100 HST with Belly Mower 3Point Blade, 3Point Scoop, 3 Point Carry-All,
Judging by that observation, one glo-plug has left the buildingI was listening closely to the video and it sounds like it's occasionally missing on one cylinder. Makes me wonder if you have a bad or funky injector... It also appeared to puff white smoke when it "missed".
Just a thought.
FWIW, my D750 engine has the plugs in parallel, so if one if US, the other two will (just) start it. At low RPM, when just started, you'll get whitish smoke from the cold cylinder(s) until all is warmed up to reasonable temp. It would be very unusual indeed for a pre-combustion diesel to have series wired glo-plugs. Electrical contacts are prone to causing problems. Check and clean them if you can get at 'em. Umm, they're fragile at the end you can see. Star washers are you friend, too.
And to the posters mentioning B7x tractors - yes, B7100's aren't the most flash starters out there. Need at least 15-20 Seconds glo in the tropics to get a clean start out of my machine.
