L3901 Intermittent Starting
DAA2018
Kubota 3901 4X4 Manual
Sep 16, 2023
Alabama
I have an L3901 4x4 gear-drive with just over 1000 hours that doesn’t want to start. It’s been going on about a month. When I turn the ignition, I hear the fuel pump kick in and two lights on the dashboard, but nothing else. No sound at all. If I switch the key off/on several times it will eventually try to start… a few more times then it starts up. Once going it operates fine.
I’ve checked all the safety switches, got a new battery and clutch a year ago, cleaned all connections, PTO is off, transmission in neutral, seat down, regular maintenance up to date, fuel is clean. I’m at wits end. I was thinking starter, but then saw the price and I’m hoping it might be something else. Any thoughts?
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
trial and error
Feb 16, 2023
394
386
NY
I'm gonna second worn ignition switch contacts, I could be way off base and it could still be a starter but that's my educated guess based on the info given
DAA2018
Sep 16, 2023
Alabama
I’ll give that a try tomorrow. Many thanks.
… and I pulled down a copy of the WSM, so I’ll go through that too.
5,696
I would be looking very hard at the safety interlocks.
