The B3200 had some problems early on with white smoking. They say you have to flow time the injection pump which is not a tough procedure but its a little difficult because the timing marks are made to view when the engine is out of the tractor. If you get it to a dealer they should have no problem with it. DO NOT just remove a shim thinking it will fix it, there are several different thickness shims that could possibly be under the pump in a variety of different combinations. The vibration issue was addressed by installing the updated thicker rubber mat on the floor- not really a fix but helps a little. The glow plugs are operated by holding the key in the glow position. It is a 12v glowplug system. Not sure what the manual says but I wouldnt think 10 sec would hurt.
