BX2360 with 60" deck. Won't go high enough to rotate height gauge to top, and past it. I can rotate through all the heights, but when I get to 4", it won't go into top so I can go to lower heights.
It seems deck won't go high enough. I've taken deck off and put back on. There does not seem to be anything blocking the arms from lifting it higher. If I physically lift the deck I can then turn it. By that i mean, i go as high as it will go, the knob wont turn into top. I get off the tractor, lift it up, and as I'm doing that i can rotate knob. So it is able to go high enough. It lowers and lifts fine otherwise.
With the deck off it rotates beautifully.
I have had this tractor for 11 years. I've had this issue on / off several times. Not sure why it has resolved before, but it does. This time it does not seem to be.
Suggestions appreciated.
