My 3430 for only 35hp is really built like tank, especially in the rear area. I was just wondering if Kubota uses my chassis in others with only different engines, and if true what would they be?
I doubt the L3830 has the same chassis. See above, I might have spent way too much time researching this stuff when I bought mine in ‘07. But hell I could be wrong. That’s said, all the 30s are similar. The glossy contains a few specs Tractor Data does not.According to TractorData, good chance the 3130 and 3830 are the same. Maybe 4330 and 4630 as well. There was also a 5030.
TractorData.com Kubota L3430 tractor information
www.tractordata.com
Yes, you have far more data than I have, I have just a glance.I doubt the L3830 has the same chassis. See above, I might have spent way too much time researching this stuff when I bought mine in ‘07. But hell I could be wrong. That’s said, all the 30s are similar. The glossy contains a few specs Tractor Data does not.
Oh yea, all the 30s are similar (but not the same). Just the chassis size and engine displacement/output incrementally increase though the series.Yes, you have far more data than I have, I have just a glance.Even those with a larger chassis kind of share the design though I presume.
Thanks for the response. I purchased it after finally stopping after driving by it a couple dozen times, and after about a month of haggling drove it the 4 miles home. No, I'm very happy with it and so far after about 5 years and roughly about 400 additional hours I put on it, so far, only thing I've replaced is the AC belt. Excellent machine! Does what it's designed to do.Grand L 30 series is very nice unit compared to the new offerings.
I would think the quality and durability of the drivetrain parts is the same and would be shared with current models.
And your tractor has no DPF emissions stuff.
Are you unhappy with your tractor,or just need something else?
Good Luck!
