Side blade shaft tred size.
wilk90
Kubota BX2200
Oct 5, 2023
Hi,
Does anybody know thread size (specification) for side blade shaft for Kubota Rotary mover RCK60b-22bx?
I would like to know top tread for nut holding pulley.
this long tread
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,432
1,721
Kalamazoo, MI
Most likely metric. Measure O.D. of threads and see whether it's closer to a mm or inch dimension. It won't be exact, but slightly under the nominal. Use a pitch gauge or compare with threads at a hardware store bolt.
5,257
1,043
Hi,
View attachment 113300 View attachment 113300
In Canada Home Depot's have thread pitch samples where you can try your nuts and bolts. I find them useful. For example 1/4" NF and M6 1.0 seem almost the same until you try in gauges.
Home Depot in USA may have the same.
wilk90
Kubota BX2200
Oct 5, 2023
The problem is that tread on the shaft is almost destroyed . Consequently I cant measure it properly. That why I am asking.
Kubota dealer told me that new one cost around $200 so I try to fix it.
Thank you for all help.
5,731
found this on Cdn site.using your model info..... #040 is only $65 CDN...NOT 200+... Nut #0230 is M18-1.5
