FEL valve problems
Carroll DuVall
L3540 tractor w724 loader-f3080 w72” deck-BX2200 w60”deck-g2160 w60”deck
Sep 15, 2023
Conway Ar
I recently had an issue with my 2010 L3540 loader.
The joystick would operate correctly when raising or lowering and when dumping but wouldn’t curl the bucket at all. It appeared to be stuck and wouldn’t budge.
After removal and disassembly, I found a broken bypass valve in the dump/curl spool portion of the valve. The stem portion was broken in two pieces and was lodged in the valve body.
Unfortunately, the repair kit for that particular valve (#YW368-00100) was discontinued and a new valve was $1200.
After lots of discussions with two different dealers, I found a replacement rebuild kit that would work on my valve.
The rebuild kit (#YS020-93100) comes with both bypass valves, springs, orings, and caps.
The new bypass valves had substantially larger stems and should hold up much better. Note that you will need to use the new supplied caps.
After reassembly, the loader works almost as good as before. I do notice the bucket won’t hold the curl position unless I operate the joystick occasionally to return it to the curl position.
This is probably due to some scarring on the spool or bore.
I’ve included pics of the original bypass valve and the new one and an invoice for all the orings and sealing washers needed. Total cost for parts was around $200.
The repair required removal of the seat base assembly, right rear tire and fender.
The only “specialty” tool I needed was a 27mm line wrench.
A schematic of the valve will help with disassembly and reassembly.
Carroll DuVall
Sep 15, 2023
Conway Ar
I’m sure you’re right
There wasn’t a description of them in the rebuild kit
Smokeydog
Jun 2, 2020
756
724
knoxville, Tennessee
Nice write up and details on a major repair issue. Good job.
Wonder if the valve replacement would have had the upgraded parts?
Carroll DuVall
Sep 15, 2023
Conway Ar
I’m not sure that it would
My impression from the what the dealer said was that the kit I bought might have been for a different valve
n1ncha
B3200
May 28, 2024
I have a B3200 with LA504 loader. Came across this post when I searched for “YW368-00100” and the parts site said my only option was the $1200 full assembly. I went to my dealership and showed them this post. He spent 15 minutes or so looking around and we came to the conclusion that the “YS020-93100” kit should fit my loader if it fit yours. Have you had any issues with it since you installed?
For the next guy this happens to:
My loader handle got stuck in the float position first. It worked for a moment and I was able to get the boom cylinder to lift, but then the handle got jammed. I sort of moved it in a circle then the boom started working but the curl position was now jammed. I thought maybe at first it was the lever lock mechanism getting in the way, but I removed it and noticed the curl spool could not be pushed in at all. I removed the plugs (37) on the valve body and noticed the load check (40) for the bucket spool was totally missing. I got the boom spool out and it looked fine. For the bucket spool I had to be a little rough with it and was finally able to bang it out. I found a broken o ring (23) but no check valve. I had to take off all the hydr lines, remove the whole valve assembly, fill it with brake cleaner and swish it around until the broken pieces came out.
comforthill
B2620,back blade,mower,tiller,loader,middlebuster,landscape rake
Oct 14, 2018
53
Lewiston
Had the same problem with our B2620 . The curl function will bleed down with or without a load. I was able to find one ( and the only 1 ) kit left in Michigan. It was the YW368-93100 at a dealer close to me. We had to drive 100 miles one way to get it. Upon arriving the lady in parts had pulled it aside and when I went to pay for it she was appalled at the price. The kit with 6 little pieces in it was listed in Kubota Pricing at $ 1100.00 ! They had a new spool assembly for $ 998.00. It was the only one available in the northern part of Michigan. The new price for that after this one was sold would be $1175.00. I bought the new spool assembly and the the gal in parts was on the phone with Kubota parts trying to find out why the kit was so over priced. They told her it was because they no longer make the parts and the number crossed over to the new spool body number picking up the same cost. The owner said sell it to me at their original cost of $ 75.00. I bought it also. We are going to replace the spool assembly later this summer to get the bucket working properly. Thanks for posting the parts numbers.
5,025
I assume you eliminated the bucket cylinder(s) before popping for the valve.
